blr_p
Pilgrim
Won't a pipe from the hot tap to the inlet work ? if you can make it work with buckets of water that is fine but then it will want more as the program changes isn't it ?Yikes.. Nope.. Can't connect it to any hot water outlet. Since it's a top load I can manually fill a couple of buckets. The issue is the geysers are instant so this task takes time.
What do you suggest one should do to try and get rid of the mold without opening the machine up? Getting quite fed-up of this
You will need to do some maintenance washes. Try this
Atomic Washing Machine Cleaner Powder for Perfectly Cleaning of Tub/Drum -[Tested By ACPL LONDON] 150 GM X 2=300 GM: Amazon.in: Health & Personal Care
www.amazon.in
Two packs. Try one and see if it makes a difference.
Reviews seem decent.
Do you have a turbo clean option ?
