codwapeace
Galvanizer
That bolded bit should guide you then.Show I decided not to buy IFB due to a lot of negative reviews for after sales.
Saw a lot of Bosch Models but planning to zero on LG 7KG or 8KG model (pressing towards 7KG).
Reason for buying LG is mainly they are giving 1 year additional warranty (worth 2400INR) + we have had a very good experience with LG after sales service for our microwave and refrigerator:
They say 7 is enough for a family of 3 to 4. heh, don't believe it.7KG that I zeroed on:
LG 7 kg Inverter Fully-Automatic Front Loading Washing Machine (FH2G6HDNL42, Luxury Silver, Inbuilt Heater): Amazon.in: Home & Kitchen
LG 7 kg Inverter Fully-Automatic Front Loading Washing Machine (FH2G6HDNL42, Luxury Silver, Inbuilt Heater): Amazon.in: Home & Kitchenwww.amazon.in
8KG model for the above:
I also get a 10% cashback as HDFC card user so that helps bring down the cost as well
Both have over a hundred reviews and the average rating is 4 stars. Says a lot.
In case you want white color, the newer series is the FHT, the FHT1007SNW comes in white, this model has the same size drum as FHT1208 8kg model( which I have), only difference is the FHT1007 lacks wifi and spin is limited to 1000rpm. Haven't touched wifi , (useful to download new cycles and remote start the machine) since the initial days. Haven't bothered to reconfigure it after I changed my router.
LG runs quiet but how loud do you find its drain pump noise compared to your Whirlpool ?The lg guys won't level it, they just level it by hand shaking the machine, So buy a spirit level and do it yourself. I had to readjust the level atleast 3 times, (floor not even) now the machine doesn't vibrate in spin tested till 1000rpm. Still no the vibration is more compared to my 11 year old whirlpool.
That 10 cm more increases the drum volume by half. The drum volume going from 6 to 8 increases more than going from 8 to 9kg@blr_p ...I agree with you on the 8KG part....I was just comparing 8KG for dimensions and its just 10 cm more in depth so checking to see if it would fit properly.
External dimension for depth.BTW - There is no drum dimensions given so how do you know that the 8KG is equivalent to your 7KG LG washer? @blr_p
The Lg overall is quieter then the whirpool , in the whirlpool you can hear the motor in spin cyle at 30feet away (even when new), can also here the clothes tumbling sound , the whirlpool pump is significantly louder compared to the Lg, when the spin stops and pump is still On, you can hear it 30feet away in indoor ambient noise.LG runs quiet but how loud do you find its drain pump noise compared to your Whirlpool ?
Wow and i thought the LG one was quite loud alreadythe whirlpool pump is significantly louder compared to the Lg, when the spin stops and pump is still On, you can hear it 30feet away in indoor ambient noise.
WAB16060IN
I've been weighing my loads to get an idea how much and its either 3kg or a little less for close to a full load.I guess you get away with that by using hot cycle. While I use more detergent with cold cycle. So more power bills vs higher detergent cost.
I have never checked, but I thought that there was a choice of spin speed with "Delicate" setting. I think "Delicate" reduces the spin speed compared to "Normal".Wow and i thought the LG one was quite loud already
Post automatically merged:
Bosch 6 kg Fully-Automatic Front Loading Washing Machine (WAB16060IN, White, Inbuilt Heater): Amazon.in: Home & Kitchen
Bosch 6 kg Fully-Automatic Front Loading Washing Machine (WAB16060IN, White, Inbuilt Heater): Amazon.in: Home & Kitchenwww.amazon.in
Like Gannu's
Fixed spin speed of 800 rpm. No choice of spin speeds. Do you at least get to specify no spin if desired ? i don't think this option is even there
Notice how this one at least has a boil wash whereas the IFB of similar value skips it.
So i get away with 20gm for medium and go up to 30gm for more soiled
If i were washing just jeans and the weight got closer to the max ratings i would up the detergent dosage
I don't think you can do that. Can you do that with any of the automatics? I did not use any that had this option with automatics either in India or in common areas in the apartment buildings in America. May be high end automatics have this option.Do you at least get to specify no spin if desired ? i don't think this option is even there
Delicates is the reason i asked.I have never checked, but I thought that there was a choice of spin speed with "Delicate" setting. I think "Delicate" reduces the spin speed compared to "Normal".
LG offers a no spin option. It will drain the water but the clothes will be soaking wet and heavy. You'd have to hand wring them after if desired.[I don't think you can do that. Can you do that with any of the automatics? I did not use any that had this option with automatics either in India or in common areas in the apartment buildings in America. May be high end automatics have this option.
LG 7 kg Inverter Fully-Automatic Front Loading Washing Machine (FHT1007SNW.ABWPEIL, Blue and White, Inbuilt Heater) : Amazon.in: Home & Kitchen
LG 7 kg Inverter Fully-Automatic Front Loading Washing Machine (FHT1007SNW.ABWPEIL, Blue and White, Inbuilt Heater) : Amazon.in: Home & Kitchenwww.amazon.in
This is good enough
That's the one adder linked to.Hey Man...Somehow I thought you advised to go for the 7KG one which I had suggested earlier
I got the same machine which I linked in #102 and I went with what you said in #103....Machine may be small but I guess my parents are happy...
there were too many messages but no concrete recommendations so I guess thats what got me confused
Has it ?Alright then.. finally got back home and used a packet of the atomic washing powder.. was manually filling hot water and running multiple on off cycles to increase the run time.. man so much gunk came out.
Hopefully this has improved things.
Finally gonna wash some proper clothes to see if it has helped
Have you noticed that with other products you used in the past ?man so much gunk came out.
When i tried it in my front loader i noticed the clothes had an odd smell which went away with subsequent washes.Hopefully this has improved things.
