thegatekeeper said:which one is better for hd6850-
http://www.plugloadsolutions.com/psu_reports/SILVERSTONE_SST-ST50F_ECOS 1315_500W_Report.pdf
http://www.plugloadsolutions.com/psu_reports/SEASONIC_S12II-430Bronze_ECOS 1240_430W_Report.pdf
http://www.plugloadsolutions.com/psu_reports/COOLER MASTER_RS-450-ACAA-D3_ECOS 2477_450W_Report.pdf
Aneesh@4GHz said:CX400 is not avail here,only cx430 is available for 2600rs,fsp is also not available here,which one should i get?
Hades. said:Spend 400 bucks more and buy Seasonic S12II 430w from TheITWares...
Aneesh@4GHz said:Guys finally found FSP SAGA II 500W from a dealer,he quoted 2050RS + Tax.Seems like a good price.![]()
Hades. said:FSP Saga II 500w is an okish psu... Its not even 80+ certified... Why dont buy something better when you really can afford to...
DarkAngel said:Get the Gigabyte Superb 640. It has better efficiency that the FSP SAGAII. Else try to get a Seasonic S12II 430w or a Corsair CX400 if you can spend a bit more.
Aneesh@4GHz said:Here only Coolermaster Real Power 460(3600rs) , cx430(2600)rs ,FSP 500W (2050rs) and vx550 (4650rs) are available,I am searching for Antec Neo Eco 400 and Seasonic S12 II 430
Searched for CX400,But no one had that and the funny thing is once i went to a dealer and asked for CORSAIR power supply,he told me corsair is not available here,i can give you Odyssey psu.LOL.I ran out of there...![]()
Aneesh@4GHz said:Guys will a corsair cx400 will draws more power than my current local intex crap?One of the dealer said,if you change the psu to a higher watt one,your power draw will increase and electricity charges will increase.![]()
Thanks bro.Got it.Infected said:The 650W if is 80% eff. then its losing 20% as elec as heat which is much higher as compared to a 400W with 80% which is losing 20% of it via heat generated...
SO the 650 is losing 130 off Watts and the 400 about 80 watts ...
hence the consumption is more...
and therefore lesser back up!!!
What dont you understand?
Really people it is hard to understand maybe, but not rocket science..
Higher watt SMPS will lose more Watts to heat if they are equally effieient.
Moral of the story:Higher watted PSU is not better on the contrary will make you consume more power,
it depends on the consumption of the pc AT IDLE AND LOAD....
Infected said:Really people it is hard to understand maybe, but not rocket science..
