Review Ultimate WATER PURIFIER Buying Guide.!
Hey guys...! I wanted to buy a Water Purifier recently... and call it a habit.. But I NEED to EXTENSIVLY research something before Buying. So.. I thought Let's share my research.
Most of us just drink RO Water without even knowing what we are drinking. In Most cases.. The RO Water we drink is just a tasteless liquid which has no health benefits at all but just a medium to quench our thirst.
This is a comprehensive Guide covering most of the aspects one should look at before Buying a Water Purifier. I Focused upon HEALTH instead of fancy Features.
First Confusion is always about.. What to Choose...eh..? I mean.. there are SEVERAL VARIANTS..! RO.. UV... UF... NF... Alkaline... Copper... and even their SEVERAL Combinations..!!!! :eek:o_O.
FIRST AND MOST IMPROTANT STEP :
If your TAP Water TDS is Below or around 200 mg/l --> UV + UF Combination.
If your TAP Water TDS is above 300 mg/l --> RO+UV+UF+ TDS Controller Combination. ( Set Water Output TDS above 150mg/l ).
If your TAP Water TDS is above 800 mg/l --> RO+UV+UF Combination.
Explanation.
1. Before Buying.. Always.. and I mean Always Check the TDS of you Tap Water. You can use any TDS metre available on Amazon ( around INR 250 ).
Now.. If your TDS is around or below 200 mg/l... YOU DO NOT NEED RO.. I REPEAT.. YOU DO NOT RO. Why.. ?? .... cause RO is a process that removes most of the ( Around 90% ) TOTAL DISSOLVED SOLIDS / SALTS ( TDS ) from your water and makes it slightly ACIDIC in nature. And as you know.. Human Blood is slightly Basic in nature and thus drinking acidic water on a regular basis increases acidic content in your body.. making your immunity slightly weaker. If you use RO in this case. Your Output Water will have a TDS around 20 to 50 AND PLEASE READ THIS CAREFULLY... PLEASE DO NOT DRINK ANY WATER WITH TDS BELOW 150 mg/l on a regular basis ( EXCEPT COCONUT WATER which has a surprisingly high TDS OF MORE THAN 1000 mg/l ) If you really care about your health. :). You can see this article. Also. do note that TDS around 300 mg/l is excellent for you health ( WHO Report ).
Now.. it's clear You DO NOT need RO if your water TDS is around 200 mg/l. Still.. It may contain some impurities as well as harmful bacteria. So.. You will need a UV ( for organic impurities ) + UF ( For inorganic impurities ) Combination in this case.
2. If your TDS is above 300 mg/l --> Go for a RO+ UV +UF + TDS Control Combination. Because.. even in this case.. RO will decrease your TDS to around 50 to 70 mg/l... BUT here.. You also HAVE A TDS CONTROLLER.
Now remember... A Water Purifier works on several steps. First Water passes through Several Filters.. then through RO Membrane.. Then through UF Membrane.. then UV.. and other membranes if any and finally in the Storage tank.
Here.. the TDS Controller bypass some of the water directly to UF Membrane instead of passing it through RO and then add that water into the output of RO Membrane... thus increasing TDS by adding original Salts present in the Tap Water. So.. your Output TDS will be whatever you desire below your Tap Water TDS. I recommend above 150 mg/l.
3. If your TDS is Way above 300 mg/l.. I mean like 800mg/l or above
.. you DO NOT NEED TDS Controller... as After RO Process.. your Output will be around 150 mg/l or above. So.. Go for a RO+UV+UF Combination.
NEXT STEP :
Electrical Type.. / Mechanical Type / Or a Combination of Both.
Answer is simple.. A combination of both BUT Please do note that some Electrical Water Purifier DO NOT allow Water Output when there is a power cut even if Water is present in the storage tank. So.. check before buying.
NEXT STEP :
Mounting Type... / Table Type / Undersink Type.
product-500x500.jpeg Undersink Type.
It really depends on your preference. Mounting Types are Wall Mounted.. Table Types are put on the table... and Undersink types are used in households having smaller kitchen or no space for wall mounting and table.
NEXT STEP :
Storage Tank Material:
More than 95% of the Water Purifiers use FOOD GRADE PLASTIC as a Water Storage Tank. But a few also use Stainless Steel. Some Water Purifiers that offer Hot Water Output have a combination of both Food Grade Plastic ( For Normal Water Tank ) and Stainless Steel ( For Hot Water tank ).... I would suggest to go for Stainless Steel. Still.. it's my personal opinion.. rest is your choice.
Stainless Steel Storage Tank Water Purifier.
NEXT STEP :
Alkaline Membrane
or Copper Membrane or Both.
This is also the most confusing part. Alkaline Membrane can be used if you are using RO... as it adds some basic salts in your RO Output Water increasing it's basicity as RO Water is slightly acidic in nature.
The Problem is there is no hard evidence that such water is really good for health. Some studies have shown that such water really helped many people to gain better health.. even removing joint pain... while other studies have shown no conclusive results. So.. it's your preference.
Now Copper Membrane is just a marketing gimmick. Don't go for it. Rest is your choice.
CRUCIAL STEP:
Sales After Service and Yearly Charge.
Many Companies like Kent or Pureit.. provide better service in some areas only. IN MY AREA.. KENT SERVICE is ABSOLUTLY pathetic. So.. please consult your neighbours or even online about the service of the company.
Also.. some Water Purifiers have an annual charge as high as 5K ( For Filters and Membranes ) while some has around ( 2K .. The minimum I Saw ). So.. check this beforehand.
That's it... follow these steps and gift yourself and your family a healthy Water Purifier. Again.. it's not a comprehensive guide.. as there are several features.. like Hot Water or Cold Water Output or fruit washer or Digital Display...and many more ... that today's Water Purifiers offer. And it's very important not to favour such fancy features over health. Please Prioritize You health.. and then your environment.
Finally.. Keeping all of the above in consideration.. I have decided to Go with BePure.
Now.. you must be thinking.. what's BePure..? Never heard of it...!???
Bepure is actually an Indian Startup providing Water Solutions. It has even won Silicon India Award and has many favourable reviews online.
So.. I am buying it's Bepure Alken Stainless Steel 12L ( RO + UV +UF + TDS + Alkaline ( Let's try it ) ) Model with an annual charge of around 2K. If anyone has used it.. Please write your experience. Thanks.
I will edit the Guide with Pictures later as I have been writing for over an hour now.:oops:.
Filterkart is also a good resource for water purifier, particularly in Delhi. @ROTECHNICALXPERTS this channel on youtube will provide you assembled Water Purifiers in various types of cabinets including the one's with SS tank.
Don't fall in to Gimmick like TDS adjuster. Also, having a UF filter after RO has absolutely no meaning.
In tank UV sterilization is good ONLY if your tank is SS, otherwise avoid it. Also make sure that the UV chamber is SS. Youtube Channel reviewmaza will also provides various filter options in and around Maharashtra.
Delhi has some good suppliers for RO. I bought my current RO in Delhi from similar assembled seller for 3.5~4k in 2015. It'll be 10years come april.
do you know any place to get in-tank UV as a unit only product?
i dont want regular philips made UV chambers..
Philips doesn't makes UV chambers. It makes UV ballasts and Lamps.
Why?
I have a pureit with plastic tank
AFAIK None of the Pureit model provides in tank UV. Once water is in storage tank, it is never exposed to UV in case of pureit.
yes low TDS some peace of mind but want something for bacteria, pathogens, chemical residues etc..
read a lot about NF can do this with fraction of cost to RO so more inclined towards it..
do i really need carbon filter too.. ?
i am thinking, sediment filter -> NF -> UV (if i find it) -> old filter SS tank..
i think that should be enough
Bacteria , Pathogen and Viruses can be filtered by UF filter itself. NF/RO pore sizes are even smaller. A carbon filter will enhance the taste of water and catch organic impurities, so it is advisable to put a pre-carbon filter. If water is of low TDS you are good with a spiral wound UF filter because NF will involve additional cost of booster pump and also wastage of water.
There's no surety that low TDS water is also free of micro/nano plastics, pesticides and pharmaceutical residues. NF can help a lot in this regard but an RO performs the best in this scenario. It won't waste much water as your TDS is pretty low already.
If you want to stick with NF, then incorporate carbon filters as well to catch few more bad guys.
A carbon Filter will NOT catch any "more bad guys" than UF/NF/RO filters. Carbon filter catches the organic matter and some chemical impurities and along with sediment filter it helps increasing life of UF/NANO/RO membrane. That's why you should not use POST carbon filter.
Yes it will.
He wants to use pre filter + NF. This combination is not sufficient to remove all the dissolved chlorine, alum, medicine residue and agricultural runoff.
City guys primarily get sewage treated water which contain pharmaceutical residues. Other folks get traces of agricultural runoff in their drinking water supply.
I didn't suggest him to specifically use post carbon filter - which is mainly a polisher. But even if he unknowingly uses some kind of activated carbon filter 'after' NF, it's going to catch unwanted chemicals that the NF missed.
Reactions: vink
NF filter will catch everything that a carbon filter can and more. It can remove suspended solids, colloids, bacteria, viruses, pathogens, color, hardness, and total organic carbon (TOC).
However it exhibit great performance deterioration when contacting with high concentration chlorine solutions, hence a carbon filter is advisable Before NF/RO membrane. Putting a carbon filter after NF and thinking it will "Polish" the water serves no purpose and is pure marketing gimmick.
I rest my case here.
Behold my Ultimate creation,
DIY with parts from Amazon.
Stage 1 = Prefilter + Sediment
Stage 2 = Pre-carbon
Stage 3 = UV (Industry Grade SS with Philips UV Lamp)
Stage 4 = Copper filter + UF
How much for the total setup? Give individual parts price list & fitting price also.
My observations:
1. You have used a very small sized UF filter, it is actually a Micro filter sold in the name Ultra Filter. The difference is in pore size. Ideally use a Polysulfone spiral wound Ultra filtration membrane (similar to RO membrane but no reject water).
2. The UV Chamber in pic is very good, but it will use a UV lamp with 4 pins on single side. This type of UV lamp is not available easily, specially of any reputed make like philips. If you can tell me a link to buy it will help.
Costed me around 2.5k since my water TDS was already 60-70ppm i dont want to spend much. only concern was UV where i invested the maximum 1000/-.
All items are bought from amazon, expect the prefilter which i taken from my old one.
You can search Konvio parts from amazon.
UV Link: https://www.amazon.in/dp/B0DJKT19G5?ref=ppx_yo2ov_dt_b_fed_asin_title
My observations:
Yeah,i noted that. since the prefiltered water is already 60-70ppm i didnt want to invest much.
here is link for UV set: https://www.waterpurifieronline.com...th-uv-choke-adapter-6w-for-all-water-purifier
Thanks for providing all the links. I was specifically looking for the replacement UV lamp as I have same barrel but I am unable to find a replacement lamp for it. Let's see if wellon provides the replacement lamp.
Reactions: bala07
today got installed this model and after 2 rinse cycle water still taste funny measured ppm is around 30 ,i only took a sip and the taste is still in my mouth its been hours, is this supposed to happen when you change to a new one also its 30 how do i increase it manually
might be due to the remineralizer(copper thingy)
I bought this
Take a look at this Pureit by HUL Advanced Max 6 L Mineral RO + UV + MF + MP Water Purifier Suitable for all - Borewell, Tanker, Municipality Water on Flipkart
In 2022.
Every 6 months I need to change the GKK filter for 3.2k both inside & outside filters.
Is there any other way to get these for cheap or any other water filter which will give me better maintenance? Please suggest. Thanks.
The TDS adjuster should be inside along with the filters. You may need to open the back cover to adjust the TDS (usually a small adjustable screw type near the inlet filter)
update: before adjusting tds i wanted to check if it will adjust itself but today after 2-3 more cycles the water ppm came down more its 15ppm now . what is happening.....going to adjust rn
The low cost unknown brand Purifiers usually deploy good for nothing filter cartridges. A good RO membrane itself costs Rs. 2000+ so if you are getting a RO Purifier for just 5k, its quality is going to be questionable.
The bad taste can be due to a bad carbon or RO or combination of these filters. Low cost carbon cartridges are not GAC but some manufacturers are simply using coal powder.
Replace the filter cartridges, buy it from a reputed manufacturer from Amazon ( Wellon/Colandas/KNL/Aquadove/Aquadyne/ Bio+ etc).
I bought this
In 2022.
This is the problem with every Big Brand Water Purifier. They usually design replacement cartridges of custom size, some manufacturer even put RF chip so that using equally good or even better after market cartridges becomes impossible. Also, you don't need to to change RO membrane every 6 months, they last for more than a year easily.
Aquadyne makes a compatible kit for your pureit model and it can save you at least Rs.1000/-. Also, instead of replacing RO membrane every year replace it after 12-15 months. Other filters you can replace it in 6-8 months. Link for compatible kit is Aquadyne's RO Service Kit for Pureit Advanced Max
So my cousins were using Livpure Bolt purifier..Bought last year.
Since water wasn't properly coming, their service engineer showed up without even complaining it seems..
So he checked and asked to replace membrane and sediment filter, costing 3600.
They thought warranty would be available but they said no warranty on filters.
Can anything be done or just spend the money?
Dunno about your issue, but there is a scam by some of these companies where the pcb suddenly stops water flow after x hours even if filter is fine.
And then they try to force unnecessary filter changes. There is no warning nothing, just water stops.
We had some trouble last year with this ( Aquaguard/eureka forbes), after changing to new unit. Last one ran for more than a decade without issue.
We eventually had the service company change the pcb few months back and now its running without issue.
Ideally water flow should just keep reducing as it accumulates stuff.
All this was done probably after some shitty American 'capital' company bought Eureka forbes.
I have heard that atleast one other company does the same, maybe kent. Dunno.
As per what he said to them, the membrane and sedmient filters are fully blocked with filtered wastage, "so they have to be replaced."
The same purifier which I use by rent, never gets that issue and runs fine and won't even require filter changes even after a year.
Now membrane+sediment itself is 3600.
Ya agree about eureka frbs. My parents had that in the past and it always required one thing or the other and they were always making sure customers pay for amc.
It was a shitty experience and my dad just stopped using it.
