Airtel fiber on bridge mode?
On the airtel modem. And what you have a after the modem is called ROUTER
Yeah ok
Always i get the refund for downtime. but being without internet as my community has exclusive aggrement with Airtel due to new building
Nokia
Nokia G2425G-A
I meant to ask if you have taken a static IP that would have changed your account number :confused: ob: :confused: ob:
Possible to enable this bridge mode thing on a zyxel PMG5617-R20B router? Airtel pushed some update to the router few weeks ago and now I cannot change dns. There was an Apply button next to the dns field but they removed it now. What’s their email btw for requesting to enable bridge and shit?
Well now bridge mode is working but WiFi on airtel modem is also working .
You have option of disabling wifi on the modem
But I thought when bridge mode in enable the airtel ont won’t be connected to internet at all because it only works as modem . That means airtel onts WiFi will also not work .
It should not. Check if you’re behind double NAT. Go to whatismyip.com and see if that matches the WAN IP of your non airtel router.
It’s not matching
Didn’t work for my fiber router :grumpy:
Dunno. Different router different system.
What are you trying to do ?
Login and see what options are available.
Set it in bridge mode so my router can take over
Your router name and model no
OP what is your ONT model and is the bridge mode working fine now?I am also trying to the same setup for my home network!
Mine is Zte model no I don’t remember and yeah after sending mail to net@airtel.com they will create a complain service no and then local technician will call you and ask your problem and then you will have to explain him that you need bridge mode enabled on your router . Then that technician will call the noc team and get it done . Also it will be active on lan port 4
In a similar situation, sent an email to net@airtel.com asking them to enable bridge mode.
Let’s see what happens next. Heard lot of horror stories lately on this with then pushing to buy static IP to enable bridge mode.
They will cave if you push hard, sent a strongly worded mail to appellate, use chatgpt if you want.
That’s how I got ipv6 enabled after them pushing me to take static IP, when I asked for ipv6 (pretty idiotic)
