red-devil
avi I think the passwords are asked pretty much every time I try to install an app..
Looks like somehow chrome can play things like live tv on ndtv.com in the background.. I'm actually doing that right now ;-)
This may even make me not return it
Btw are you done with your review? I'm eager to read your take on iPad air..[DOUBLEPOST=1386729796][/DOUBLEPOST]Another question: is there a way to prevent the auto reload of web pages? I thought only safari did that but now I see that even chrome does it..any add on or something to block this?
Actually I have many pending downloads in my iTunes account. So I came to know that its because of that. I have some 40GB of pending downloads, will complete them sometime and then see if I have same problem.
Make sure you are using the same iTunes account, see that here Settings > iTunes & Appstore, your Apple ID should be there at top. And also see, Settings > General > Restrictions > Require password, hope it is not set to immediate or something.
Auto reload is not exactly an issue (if I am not wrong), to have a fix. I mean it's expected to happen. It's also one of overblown issues of apple products. It is due to low RAM of iPad. So unless Apple increases their iPad's RAM, it will be there. And buttholes at Cupertino think they are great at optimizing & stuff, so they will never acknowledge this problem of iPad. When you open a new tab in Safari, if there is less memory available (God knows how it will be less memory even with 1GB of RAM
), Safari just dumps all of the content of previous tabs. Only solution is, close all the memory hogging, RAM requiring apps. Do not open big apps which take huge chunk of RAM. Keep minimal apps open and it will work fine. Just yesterday I opened 5 tabs and youtube was playing in background and I made a post here in TE, it worked fine.
It sucks but there seems to be no solution other than this or increasing the RAM. Or there could be some memory leak bug.
I am not getting enough time for review, will take few more days
btw here is one Infinity blade II Redeem code for you, have fun :
MJNMWMWTH3JP
