red-devil
I use linux primarily. SO have no way to install iTunes.
Is there any other way to sync?
Best would be if i can transfer files over wifi to my iPad and use some player which can play from the filesystem . Possible?
If you're only looking to transfer specific files then you can install OPlayer on your iPad and use that to download those specific file(s).
Although I'm not quite sure how you can sync things between linux and ios..
