blr_p
Oracle
I find higher rated fridges which are larger consuming similar to smaller fridges with lower ratings.But like you said the BEE ratings get derated over time. Essentially if a maker goes to the BEE insitution and say the newly made fridge consumes less power, and present the data, it gets better star, and as a result the existing models' star rating will come down. But point to be noted is their consumption whatever is recorded on the product label stays the same almost.
If you were to compare a 4 star of today with a 4 star from previous years of similar capacity then are they similar ?
That fan keeps the temperature uniform or as close to across the fridge. You want a fridge with such a fan. I don't consider power savings without it as worth it.The con side of this improvements is increase in dependency/complexity on electronics. For instance, there will be a fan for circulation which prevents frosting. This fan consumes around 6w, and is of type single phase induction motor. Now most makers are targeting to make it BLDC to bring down the power consumption. The con side of this is increased electronics to drive the BLDC motor, and as a result cost involved. Likewise makers go for alternate electronic spares to bring down the losses in inverter bridge.
I've seen videos where that fan can get frosted and makes a very loud noise and the most common reason that happens is due to overloading the fridge.
I don't know if your fridge has door cooling but the one you linked does have it. That is a good feature to have in a fridge for the reason mentioned.
