Kaleen Bhaiya
Herald
I use Wipro smart plug 16A to measure power pattern on a daily basis. Wished I could share the monthly pattern, but Android or Wipro app won't allow lateral screenshot. It was mostly around 3.8-4 units, sometimes even higher than 4 units. For Oct 2021, my average units consumed was 119.71 so almost 4 units/day. For Nov 2021 it was 116.07. @dexterz you will need a 16A plug as both AC and fridge have higher ampere reading. Check the link for wipro one. I have been using it since last June. I have two such meters, for AC and fridge respectively.Did you measure with a power meter this 4 units a day ?
Hardly think so... 10C difference is too much. Average temps in kitchen should be 29-30C.Is your kitchen ten degrees warmer than mine ?
It has more to do with how much cooling you want. Let's say the knob reads "1" which corresponds to 7C, "2" corresponds to 6C and so on. So when we keep the knob at "1", the compressor would reach 7C before shutting off. But you would feel this is not enough given the heat outside, hence you decide to crack the knob to "3 or 4 or 5" culminating to 3C. The manual compressor or fridge won't have that smartness to determine whether you need more cooling or not based on outside temps. Lack of sensors maybe...?I've never understood the need to change the regulator settings when seasons change. If a desired temperature is set then the fridge should work to maintain that temperature regardless of the season. It might have to work a little more frequently in the warmer season but I don't think any tweaks are necessary.
This I haven't checked. But I observed a pattern(too early, I know) where in the afternoon today and yesterday around same time it went full power. The compressor is audible but not like the earlier one. I checked on Wipro app and found it was pulling in around 130W+. My meter cannot measure the duration.130-140 units over how long a period ?
