Pogoplug Pro - $29.95 - Approx. 2.75k shipped - Low power download box etc
Does anyone knows whether getting it from SNS is a good idea ? I hear they the products much faster than ICC World and are cheaper
How much does these Ethernet Switches cost good ones ? reading the install guide it says check your Router DHCP assignment to identify the I.P how to identify without the router ? Just want to make sure before i order it would work without the need of router.
Deathbearer said:
I M From Mumbai Buddy
I have ordered one using SnS, if you want, I can order another one for you as well. We can save some bucks on shipping. Please let me know immediately so that I can inform Pogoplug support.
I do not have the device with me but in the reviews i read Wifi is good and streaming via wifi is also great with both devices connected over Wifi. The pogoplug firmware is buggy though.
Anyways you will install arch linux over it so its better to get to know about the wireless drivers working from archliunxARM forum
ok plz order one for me PM me ur account details. i will give u my contact info
Cheapest Gigabit switch i could find was 20USD.
Newegg.com - gigabit switch
PM'd you. Decided to get one. NAS goes out of the window.
For those of you planning to order through SnS, please note that the shipping weight of the item is close to 2.4 lbs so through SnS, shipping alone will cost about 1.3k plus if you order it directly the exchange rate is close to Rs 54 whereas ICC's rate is only Rs 51. On top of this there will be customs as well.
So right now, without even adding customs the cost has come to Rs 3000 through SnS whereas through ICC its 2.5k including everything.
prasanth11 said:
Goflex net or Popoplug pro which is better one?
GoFlex Net
1.2 Ghz Marvell Processor
2 SATA Ports with Port Multiplier Support
1 USB Port
More common hardware and more support
Price almost double
Pogoplug Pro
700 Mhz Dual Core Processor
4 USB Ports
1 Internal SATA Port
Wifi
Newer hardware, less support (Although Archlinux is supported), Older Kernel
Cheap
varkey said:
GoFlex Net
1 USB Port
Price almost double
Pogoplug Pro
4 USB Ports
Wifi
Cheap
will wifi work after installing Archlinux
I am awaiting confirmation mail from Pogoplug support team. As soon as I receive their confirmation, will order 2 more units.
@Deathearer, please share your number.
Placed my order hoping ICC World ships it within 5 days.
@varkey
Is there a complete tutorial on getting most things on PogoPlug , something which is technical in nature I can figure out the specifics since the guide posted on main page only has arch linux.I did checked archlinux forums not much of info there.
Also is Gigabit switch required ? Are these switches easily available ?
Info on Power consumption
http://archlinuxarm.org/forum/viewtopic.php?f=29&t=1581
Gigabit switches here start at 3K for the 5 port ones, Belkin models.
I dont think it is required, but its useful for high speed transfers.
It would be required for me since my modem does not have 2 Ethernet Switches
