gopal_agrawal
Forerunner
It drains water before starting.Does it drain the water you added earlier. Or does it just add water without draining.
well, well, well, looks like Samsung has joined the rest thenIt drains water before starting.
I'm starting to wonder whether this is the reason they got rid of 'rinse hold' in front loaders. It's gone on recent base modelsNo, if you soak clothes in detergent water for a few hours, they start stinking like wet dog or something nasty. I don't know how to describe that smell. It doesn't go away even if you rinse the clothes 3-4 times. It just gets worse. Probably decomposition smell of cotton.
Happens more in a bucket since the soap is concentrated. Maybe the detergent powder and water used makes a difference. In hot water, I've noticed, the clothes start smelling bad after 3-4 hours.The thing is I've never experienced this smell problem with soaking in a bucket. Nor in a machine if I left the clothes in the last rinse cycle for a couple of hours.
Maybe they're just removing features just to charge more for their higher models. I think they even removed the favourite button or what you call, a custom preset button. The costlier models seem to have that option in the app.I'm starting to wonder whether this is the reason they got rid of 'rinse hold' in front loaders. It's gone on recent base models![]()
Soap is not responsible for the smell though. It's when it breaks down that the problem starts.Happens more in a bucket since the soap is concentrated. Maybe the detergent powder and water used makes a difference. In hot water, I've noticed, the clothes start smelling bad after 3-4 hours.
Or it allows them to charge less for people on a budget. I notice the feature is available on @terence_fdes machine and that is a 2012 modelMaybe they're just removing features just to charge more for their higher models. I think they even removed the favourite button or what you call, a custom preset button. The costlier models seem to have that option in the app.
Why not raise the back legs then? would help if you had a spotter while you did it.I wanted to ask you a question. i filled the drum to the top of the pulsator to balance the machine and saw the water is higher at back than front. The wm back legs are lower than the front legs due to a slope in the tile since it's close to the drain.
Can I use some flat wooden piece to prop the back legs higher? The front legs are at minimum height and there's a ~4mm slope towards the back.
make sure you tighten the top nut towards the machine once it is level. This is what it looks like on a front loader
I have left it overnight. No smell.@lockhrt999 can you tell us your experiences about soaking and bad smells if left too long?
Right, this has been my experience as well so it was surprising to hearI have left it overnight. No smell.
This has been known to happen in geysers say. But that is after leaving the water in them for several weeks to a month.He has hard water and that's the reason for smell. The heat is causing some chemical reaction in the hard salt. It should smell like rotten egg.
Just 3-4 hours in hot water is enough in this caseHappens more in a bucket since the soap is concentrated. Maybe the detergent powder and water used makes a difference. In hot water, I've noticed, the clothes start smelling bad after 3-4 hours.
Yes. I see steel utensils have rust marks on them after washing and drying them.Does he have hard water? @6pack ?
citric acid in hot water will restore them. Like brand new.Yes. I see steel utensils have rust marks on them after washing and drying them.
Because it's not stable. I was going to suggest a tile of some sort. Put some anti-skid tape on it.Edit: i used wooden piece to level the washing machine back and the front side i used the screws. Even though the water level is exactly the same on all sides, the machine seems to vibrate a bit at the top while running the spin cycle. So I'll remove the wooden pieces immediately. Not much confidence in them though they do the job.
I don't think they are good. The machine is not designed to run on them. They are supposed to reduce noise by adding dampening. Fine in theory but hard to achieve in practice. Never saw a review that was convincing. It's not the noise that is the problem but excess vibration caused by out-of-balance spins. Unless the machine is better engineered you will have to live with whatever noise it makes during a spin.Do those antivibration pads help
I'm not a fan of these stands for washing machines btw.or should I just get a new stand?
Nope. Just the user manual in a plastic bag.Did you get any 3M anti-skid pads with the machine? They are like sandpaper with an adhesive back. One square inch. Get four of those from the LG guy and place the machine on them.
How does this happen in FL? I mean you cannot pre-soak it in FL for longer duration.This is why people use old school Dettol. To first, disinfect the water then add the clothes and detergent. Or you could use Vanish.
I've never felt a need to soak anything with my FL. All stains come out within reason.How does this happen in FL? I mean you cannot pre-soak it in FL for longer duration.
Or adding it during the wash cycle could be effective? That is the only option I can see.
A little thought and I figure this is not the answer. Simply because it would be unacceptable at a city-wide level. Your problem in Delhi was poor maintenance in the building you lived in. You got to do your part as well which was not done in your case.I have had issues with clothes stinking when left in water for a long time when I was in Delhi. I observed that since the water was treated from Yamuna river which was basically an open drainage. The treatment at Wazirpur would regularly fail when treating water with high ammonia content.
More than a year has passed by. I guess by now there's a good build-up of mud in the inside tank.When was the last time you disinfected your overhead and sump tanks @6pack ?
A year is not too bad. I get mud in my tank too. The toilet cistern always has it.More than a year has passed by. I guess by now there's a good build-up of mud in the inside tank.
I don't know what the society does but looking at the muddy water coming from my tap, i guess they haven't cleaned the underground and overhead tanks in the building. And they don't like anyone telling them what to do so...
Generally it's unavoidable that dust/mud gathering at the bottom of the tanks given the bad quality of water. But you can totally avoid getting that gunk through your pipes and choking your taps. Just don't let tanks go empty more than half. If you do let the water level go down to the bottom, the next filling will muddy the water.I don't know what the society does but looking at the muddy water coming from my tap, i guess they haven't cleaned the underground and overhead tanks in the building. And they don't like anyone telling them what to do so...
