can you tell from where did you buy it, I'm also looking for a modular psu.ultimabasher said:Well it might come as a surprise but has anyone heard of Tacens Supero 600w?
Its manufactured by FSP, modular PSU, completely silent, rated at 85% and above all, for 3.9k. Killer deal. I got one myself and its rock stable and silent
Hades. said:Where do you live? Try to find TX650V2 which sells for 5.2k in your city...
low_bass_makker said:What happens if the power supply is in water. The SMPS in question is CM Modular 1000 watts silent PRO M. It was installed with the fan facing down. So when it flooded the half of the supply was under water and the system was off. I have taken out the SMPS from the pc and I have not connected the power till now. Will dry it completely before powering up.
But my question is will it work after drying or ????
low_bass_makker said:But my question is will it work after drying or ????
asingh said:Doubt it is going to work. Would not risk it.
Gannu said:Going by personal experience, it will.
A Dell PC was completely submerged in water at my workplace (flooded unfortunately by rain water! :ashamed and it was left to dry for over a week. It booted and worked without problems.
I'd say have some patience and leave it to dry for a week's time. I must ask however, how did this happen?
chiragsthakur said:Use a hair dryer everyday for a week to make it dry. Even a tiny water droplet can lead to a short circuit.
quixand said:^^ What say you to this ?
CORSAIR TX750 V2 POWER SUPPLY (CMPSU-750TXV2UK) | eBay
At 6K looks like a pretty good deal, don't it?
SMC has it listed @6.4K and IT Ware @ 7.2K
TheITWares - One Stop for all Gizmos!CORSAIR 750W ATX12V / EPS12V SLI / CrossFire Ready 80 PLUS SMPS
I think I'll need to go to Tirupati tomorrow.
