mav2000 said:I saw the V1 for 5.9k there...the V1 is no slouch either. But tell me quix, are you running a dual GPU setup?
Gannu said:^Not only are they future ready, but they work at their best efficiencies. On an average, most PSUs work at their efficient best when they are loaded to approx. 50% of their rated wattage. I think i've said that a dozen times in the forum!
But yeah spending on an AX1200 is blasphemy! :lol:
Soyab0007 said:reuired psu for dual core config and gt 240 ddr5 card
budget Rs2000
viralbug said:While that is completely true, isn't the power that you're counting the peak wattage?
mrcool63 said:^^
seasonic s12ii 520 would suffice man
for future updates
Seasonic s12II 620w-4.9k
Corsair 650tx-5.4k
thegatekeeper said:seasonic s12ii 520w-3.6k would be sufficient for your rig,you can add gpu like ati hd6870 or 6950,it doesn't matter if your psu is as similar as your case,you can add any psu you want,as for fans your case company such as you mentioned cooler master or thermaltake produces it's separate fans as it would be better to buy those.the PS only pulls what it needs inrelation to what the components need.If the components need 200 watts, any power supply will power that, no more, hopefully no less.If you are low on budget and you are not going to install gpu like 6850 or more then seasonic s12ii 430w-2.6k/corsair cx430 v2-2.2k would be enough,choose according your future additions.
