Review Ultimate WATER PURIFIER Buying Guide.!
Hey guys...! I wanted to buy a Water Purifier recently... and call it a habit.. But I NEED to EXTENSIVLY research something before Buying. So.. I thought Let's share my research.
Most of us just drink RO Water without even knowing what we are drinking. In Most cases.. The RO Water we drink is just a tasteless liquid which has no health benefits at all but just a medium to quench our thirst.
This is a comprehensive Guide covering most of the aspects one should look at before Buying a Water Purifier. I Focused upon HEALTH instead of fancy Features.
First Confusion is always about.. What to Choose...eh..? I mean.. there are SEVERAL VARIANTS..! RO.. UV... UF... NF... Alkaline... Copper... and even their SEVERAL Combinations..!!!! :eek:o_O.
FIRST AND MOST IMPROTANT STEP :
If your TAP Water TDS is Below or around 200 mg/l --> UV + UF Combination.
If your TAP Water TDS is above 300 mg/l --> RO+UV+UF+ TDS Controller Combination. ( Set Water Output TDS above 150mg/l ).
If your TAP Water TDS is above 800 mg/l --> RO+UV+UF Combination.
Explanation.
1. Before Buying.. Always.. and I mean Always Check the TDS of you Tap Water. You can use any TDS metre available on Amazon ( around INR 250 ).
Now.. If your TDS is around or below 200 mg/l... YOU DO NOT NEED RO.. I REPEAT.. YOU DO NOT RO. Why.. ?? .... cause RO is a process that removes most of the ( Around 90% ) TOTAL DISSOLVED SOLIDS / SALTS ( TDS ) from your water and makes it slightly ACIDIC in nature. And as you know.. Human Blood is slightly Basic in nature and thus drinking acidic water on a regular basis increases acidic content in your body.. making your immunity slightly weaker. If you use RO in this case. Your Output Water will have a TDS around 20 to 50 AND PLEASE READ THIS CAREFULLY... PLEASE DO NOT DRINK ANY WATER WITH TDS BELOW 150 mg/l on a regular basis ( EXCEPT COCONUT WATER which has a surprisingly high TDS OF MORE THAN 1000 mg/l ) If you really care about your health. :). You can see this article. Also. do note that TDS around 300 mg/l is excellent for you health ( WHO Report ).
Now.. it's clear You DO NOT need RO if your water TDS is around 200 mg/l. Still.. It may contain some impurities as well as harmful bacteria. So.. You will need a UV ( for organic impurities ) + UF ( For inorganic impurities ) Combination in this case.
2. If your TDS is above 300 mg/l --> Go for a RO+ UV +UF + TDS Control Combination. Because.. even in this case.. RO will decrease your TDS to around 50 to 70 mg/l... BUT here.. You also HAVE A TDS CONTROLLER.
Now remember... A Water Purifier works on several steps. First Water passes through Several Filters.. then through RO Membrane.. Then through UF Membrane.. then UV.. and other membranes if any and finally in the Storage tank.
Here.. the TDS Controller bypass some of the water directly to UF Membrane instead of passing it through RO and then add that water into the output of RO Membrane... thus increasing TDS by adding original Salts present in the Tap Water. So.. your Output TDS will be whatever you desire below your Tap Water TDS. I recommend above 150 mg/l.
3. If your TDS is Way above 300 mg/l.. I mean like 800mg/l or above
.. you DO NOT NEED TDS Controller... as After RO Process.. your Output will be around 150 mg/l or above. So.. Go for a RO+UV+UF Combination.
NEXT STEP :
Electrical Type.. / Mechanical Type / Or a Combination of Both.
Answer is simple.. A combination of both BUT Please do note that some Electrical Water Purifier DO NOT allow Water Output when there is a power cut even if Water is present in the storage tank. So.. check before buying.
NEXT STEP :
Mounting Type... / Table Type / Undersink Type.
product-500x500.jpeg Undersink Type.
It really depends on your preference. Mounting Types are Wall Mounted.. Table Types are put on the table... and Undersink types are used in households having smaller kitchen or no space for wall mounting and table.
NEXT STEP :
Storage Tank Material:
More than 95% of the Water Purifiers use FOOD GRADE PLASTIC as a Water Storage Tank. But a few also use Stainless Steel. Some Water Purifiers that offer Hot Water Output have a combination of both Food Grade Plastic ( For Normal Water Tank ) and Stainless Steel ( For Hot Water tank ).... I would suggest to go for Stainless Steel. Still.. it's my personal opinion.. rest is your choice.
Stainless Steel Storage Tank Water Purifier.
NEXT STEP :
Alkaline Membrane
or Copper Membrane or Both.
This is also the most confusing part. Alkaline Membrane can be used if you are using RO... as it adds some basic salts in your RO Output Water increasing it's basicity as RO Water is slightly acidic in nature.
The Problem is there is no hard evidence that such water is really good for health. Some studies have shown that such water really helped many people to gain better health.. even removing joint pain... while other studies have shown no conclusive results. So.. it's your preference.
Now Copper Membrane is just a marketing gimmick. Don't go for it. Rest is your choice.
CRUCIAL STEP:
Sales After Service and Yearly Charge.
Many Companies like Kent or Pureit.. provide better service in some areas only. IN MY AREA.. KENT SERVICE is ABSOLUTLY pathetic. So.. please consult your neighbours or even online about the service of the company.
Also.. some Water Purifiers have an annual charge as high as 5K ( For Filters and Membranes ) while some has around ( 2K .. The minimum I Saw ). So.. check this beforehand.
That's it... follow these steps and gift yourself and your family a healthy Water Purifier. Again.. it's not a comprehensive guide.. as there are several features.. like Hot Water or Cold Water Output or fruit washer or Digital Display...and many more ... that today's Water Purifiers offer. And it's very important not to favour such fancy features over health. Please Prioritize You health.. and then your environment.
Finally.. Keeping all of the above in consideration.. I have decided to Go with BePure.
Now.. you must be thinking.. what's BePure..? Never heard of it...!???
Bepure is actually an Indian Startup providing Water Solutions. It has even won Silicon India Award and has many favourable reviews online.
So.. I am buying it's Bepure Alken Stainless Steel 12L ( RO + UV +UF + TDS + Alkaline ( Let's try it ) ) Model with an annual charge of around 2K. If anyone has used it.. Please write your experience. Thanks.
I will edit the Guide with Pictures later as I have been writing for over an hour now.:oops:.
Any idea of the TAT for complaints if you face issue with the purifier ? Same day, next day, hours ? I would expect hours if the issue involves the purifier not working at all.
I live in a Tier-1 city. When service request/complaint is placed, they give a date based on availability, like 1 or 2 or sometimes even 3 days. But technician visited the next day itself everytime. Definitely not on the same day or within hours.
Never had purifier not working issue. Only once, as I said, the recharge suddenly shows not updated, and it doesn't give water, the recharge icon keeps blinking on the purifier. Then the technician arrived and corrected it from his end the next day.
Meanwhile, for my neighbor, when I placed the last service req (before replacement), even if the technician called the next day, they kept on postponing and it got assigned to a different technician every day. After 4 days, posted on twitter and it took 3 days to replace the device. But I feel this is obviously technician's negligence.
Also if the filter status is red, does it stop working or is it just a notification to change it ?
For filter life icon red, it still gives water. Actually, it doesn't wait till complete filter failure and usually shows several liters before. I filled almost 40 litres (2 cans) when filter life went red, and checked tds, it was still +10 difference only.
Also your location / locality since the service quality usually depends on location. Kent has excellent service back home in Kol while it is pathetic here in Bangalore.
Obviously yes.
Aquaguard and Kent were bad in my area though. Not 100% bad, but it was bothersome always and we had to be super vigilant everytime. Becz of these bad experiences with both major companies, I lost the interest to buy purifier. Still may buy later, but definitely not Kent/Aquaguard.
Reactions: ibose
Thanks for this guide. How often is service required? My Aquaguard salesman was trying go get me to buy a service subscription. Is it really required?
Parents use a Kent Grand Plus since last 10 years with an additional iron filter. I would note that water quality is pathetic. We are doing an AMC based on requirement which covers pretty much everything. Service is pretty good so far. Location is Rajarhat Gopalpur, near Airport.
Reactions: solo_wing
Planning to spend 8k-10k and want reliable one.
My tds is 374.
Anyone In Kolkata experienced Livpure subscription service. And can share info about it .
Thank you for your help.
I've been checking the prices. It is too expensive Kent Grand -15k-16k
I have the same at home, also around 10 years old. Worth every penny paid for it. We also have a yearly AMC for 5500, which covers everything.
Reactions: ibose
Anyone from Bangalore here who uses DrinkPrime? It has been close to a year now for me and they have not come even once for maintenance. I contacted customer care and they said that I can raise a maintenance request only if it shows on the app that the purifier needs it.
Almost every water purifier company has poor service remarks ...some less some more.
I guess I will have to take my chance .
I like Kent but too expensive...where everyone is selling for 8k-10k ...these guys are Rs 15k-18k .
But they might be better overall.
Surprised that even after paying Rs 15k and so people still have to maintain AMC for 5k-6k.
Also thinking about half of the water going waste is another thing going on in mind.
Maybe got to find a way to use that water too.
We use some of it for house cleaning and plants. You can install something like this to better manage waste water -
Also I believe some newer models output less waste water.
Then that unlimited ro water service seems cheaper. Just 500 a month so around 6k per year.
For around 2000 rupees you can buy an overhead tank with around 350L capacity. 1600 for such a tiny plastic box is robbery. Even if you search the local market for a 40L can or bucket you can buy it within 200 to 400 rupees easily.
That was meant to share as an idea. I am not asking you to buy it from Amz.
Besides not everyone has provision for overhead tank. Also if you have the time to watch a bucket fill to it's brim, be my guest.
Don't be upset. I was just saying that company is asking too much for that tiny container. I know not everyone has provision for loft tank and no you don't have to watch water fill up a bucket. There's auto shut off valves available on Amazon.
If you're giving advice you should be ready for critisism that others will point out the shortcomings of the advice if there are any. You're taking it personally like you are the seller of that contraption.
LVOERTUIG Quick Fitting Adjustable PVC Float Shut Off Valve for Tubing OD Fish Aquarium Mini Plastic Water Filter Float Ball Valve (White, 1/4 inch) https://amzn.eu/d/eN5wNiO
FEELING MALL Solar Bag 10 gallons/40L Storage Bag Hiking Climbing Fishing Outdoor Sport Road Travel Picnic BBQ Water Rinse Kit Camp Shower Tent Hand Washing Station Camp Sink Sun Heat Rinsekit System https://amzn.eu/d/1LKmvci
^ even this camping bag has higher capacity than that thing and i won't recommend this.
Lol. You get triggered easily. Not having a good day, are we ? Take a chill pill.
I am all for "constructive" criticism as long you can take yours. The valves are a good point and their are similar tanks also available with valves built in. Again I will reiterate, it was meant to share as an idea as I clearly state that something like this is an option. If you read it differently then that is your problem. I am not asking you to buy it and it was never a price recommendation.
200mg/l and 200ppm both values are same right?
Yesterday I randomly saw this post and checked the tds of my water. It was 30 ☠️ . Last year when the technician came for service I think he messed it up anyway I think I need to remove ro. Uv and uf is sufficient for now. I have kent grand plus ro is there any way I can disconnect ro and just use uv and uf or do I need a entire new machine
My tds is 374.
Does the water taste funny? did you choose any RO yet? 374tds doesn't really need a RO, maybe just a UV+UF. I haven't seen any benefit from going with branded RO systems that cost upwards of 8k. I'm still using my desi Aqua<insert suffix here> system that I got for 4k in 2015. Such systems are still available around 4~6k price point
Yes. we bought Kent Ace- Ro +UV+uf.
we got it for 9.8k( after exchanging old system)
I cannot say any difference because I am not in home town but people I ordered for seem happy for now.
I went through hundreds of machines. They all look and perform similar . It all comes down to service and Kent has bit better service then rest in my area.
Now if we need no RO but just UV and UF. We just went with all three systems .
Now TDS is 100
