Review Ultimate WATER PURIFIER Buying Guide.!
Hey guys...! I wanted to buy a Water Purifier recently... and call it a habit.. But I NEED to EXTENSIVLY research something before Buying. So.. I thought Let's share my research.
Most of us just drink RO Water without even knowing what we are drinking. In Most cases.. The RO Water we drink is just a tasteless liquid which has no health benefits at all but just a medium to quench our thirst.
This is a comprehensive Guide covering most of the aspects one should look at before Buying a Water Purifier. I Focused upon HEALTH instead of fancy Features.
First Confusion is always about.. What to Choose...eh..? I mean.. there are SEVERAL VARIANTS..! RO.. UV... UF... NF... Alkaline... Copper... and even their SEVERAL Combinations..!!!! :eek:o_O.
FIRST AND MOST IMPROTANT STEP :
If your TAP Water TDS is Below or around 200 mg/l --> UV + UF Combination.
If your TAP Water TDS is above 300 mg/l --> RO+UV+UF+ TDS Controller Combination. ( Set Water Output TDS above 150mg/l ).
If your TAP Water TDS is above 800 mg/l --> RO+UV+UF Combination.
Explanation.
1. Before Buying.. Always.. and I mean Always Check the TDS of you Tap Water. You can use any TDS metre available on Amazon ( around INR 250 ).
Now.. If your TDS is around or below 200 mg/l... YOU DO NOT NEED RO.. I REPEAT.. YOU DO NOT RO. Why.. ?? .... cause RO is a process that removes most of the ( Around 90% ) TOTAL DISSOLVED SOLIDS / SALTS ( TDS ) from your water and makes it slightly ACIDIC in nature. And as you know.. Human Blood is slightly Basic in nature and thus drinking acidic water on a regular basis increases acidic content in your body.. making your immunity slightly weaker. If you use RO in this case. Your Output Water will have a TDS around 20 to 50 AND PLEASE READ THIS CAREFULLY... PLEASE DO NOT DRINK ANY WATER WITH TDS BELOW 150 mg/l on a regular basis ( EXCEPT COCONUT WATER which has a surprisingly high TDS OF MORE THAN 1000 mg/l ) If you really care about your health. :). You can see this article. Also. do note that TDS around 300 mg/l is excellent for you health ( WHO Report ).
Now.. it's clear You DO NOT need RO if your water TDS is around 200 mg/l. Still.. It may contain some impurities as well as harmful bacteria. So.. You will need a UV ( for organic impurities ) + UF ( For inorganic impurities ) Combination in this case.
2. If your TDS is above 300 mg/l --> Go for a RO+ UV +UF + TDS Control Combination. Because.. even in this case.. RO will decrease your TDS to around 50 to 70 mg/l... BUT here.. You also HAVE A TDS CONTROLLER.
Now remember... A Water Purifier works on several steps. First Water passes through Several Filters.. then through RO Membrane.. Then through UF Membrane.. then UV.. and other membranes if any and finally in the Storage tank.
Here.. the TDS Controller bypass some of the water directly to UF Membrane instead of passing it through RO and then add that water into the output of RO Membrane... thus increasing TDS by adding original Salts present in the Tap Water. So.. your Output TDS will be whatever you desire below your Tap Water TDS. I recommend above 150 mg/l.
3. If your TDS is Way above 300 mg/l.. I mean like 800mg/l or above
.. you DO NOT NEED TDS Controller... as After RO Process.. your Output will be around 150 mg/l or above. So.. Go for a RO+UV+UF Combination.
NEXT STEP :
Electrical Type.. / Mechanical Type / Or a Combination of Both.
Answer is simple.. A combination of both BUT Please do note that some Electrical Water Purifier DO NOT allow Water Output when there is a power cut even if Water is present in the storage tank. So.. check before buying.
NEXT STEP :
Mounting Type... / Table Type / Undersink Type.
product-500x500.jpeg Undersink Type.
It really depends on your preference. Mounting Types are Wall Mounted.. Table Types are put on the table... and Undersink types are used in households having smaller kitchen or no space for wall mounting and table.
NEXT STEP :
Storage Tank Material:
More than 95% of the Water Purifiers use FOOD GRADE PLASTIC as a Water Storage Tank. But a few also use Stainless Steel. Some Water Purifiers that offer Hot Water Output have a combination of both Food Grade Plastic ( For Normal Water Tank ) and Stainless Steel ( For Hot Water tank ).... I would suggest to go for Stainless Steel. Still.. it's my personal opinion.. rest is your choice.
Stainless Steel Storage Tank Water Purifier.
NEXT STEP :
Alkaline Membrane
or Copper Membrane or Both.
This is also the most confusing part. Alkaline Membrane can be used if you are using RO... as it adds some basic salts in your RO Output Water increasing it's basicity as RO Water is slightly acidic in nature.
The Problem is there is no hard evidence that such water is really good for health. Some studies have shown that such water really helped many people to gain better health.. even removing joint pain... while other studies have shown no conclusive results. So.. it's your preference.
Now Copper Membrane is just a marketing gimmick. Don't go for it. Rest is your choice.
CRUCIAL STEP:
Sales After Service and Yearly Charge.
Many Companies like Kent or Pureit.. provide better service in some areas only. IN MY AREA.. KENT SERVICE is ABSOLUTLY pathetic. So.. please consult your neighbours or even online about the service of the company.
Also.. some Water Purifiers have an annual charge as high as 5K ( For Filters and Membranes ) while some has around ( 2K .. The minimum I Saw ). So.. check this beforehand.
That's it... follow these steps and gift yourself and your family a healthy Water Purifier. Again.. it's not a comprehensive guide.. as there are several features.. like Hot Water or Cold Water Output or fruit washer or Digital Display...and many more ... that today's Water Purifiers offer. And it's very important not to favour such fancy features over health. Please Prioritize You health.. and then your environment.
Finally.. Keeping all of the above in consideration.. I have decided to Go with BePure.
Now.. you must be thinking.. what's BePure..? Never heard of it...!???
Bepure is actually an Indian Startup providing Water Solutions. It has even won Silicon India Award and has many favourable reviews online.
So.. I am buying it's Bepure Alken Stainless Steel 12L ( RO + UV +UF + TDS + Alkaline ( Let's try it ) ) Model with an annual charge of around 2K. If anyone has used it.. Please write your experience. Thanks.
I will edit the Guide with Pictures later as I have been writing for over an hour now.:oops:.
Does the water taste funny? did you choose any RO yet? 374tds doesn't really need a RO, maybe just a UV+UF. I haven't seen any benefit from going with branded RO systems that cost upwards of 8k. I'm still using my desi Aqua<insert suffix here> system that I got for 4k in 2015. Such systems are still available around 4~6k price point
post with Images help lot more
200mg/l and 200ppm both values are same right?
Yesterday I randomly saw this post and checked the tds of my water. It was 30 ☠️ . Last year when the technician came for service I think he messed it up anyway I think I need to remove ro. Uv and uf is sufficient for now. I have kent grand plus ro is there any way I can disconnect ro and just use uv and uf or do I need a entire new machine
1 mg/L = 1 parts per million (ppm) (source google)
You can bypass the RO process by disconnecting the RO membrane chamber from the chain of various filters. The inlet water after passing through the pre filters should to uv and post carbon filter(if any) then onto storage tank.
Has anyone tried BePure nano-filteration?
I live in Bangalore and I get around 350ppm in my area. Can someone recommend any good purifiers?
Do you have impurities in water? The tds isnt that high to need ro treatment. Any UF system will do. Search for RO water purifier near me on google and get it done by your local vendor. Cheaper and should get faster service. Dont go for Alkaline water or whatever as that is a gimmick.
image of what? there are bunch of generic aqua's at the lower price band. aquapure, aquafresh, aquatec, aquagrand, hence my aqua<insert suffix>.
I mean image of water filter at your place, using since 2015, it seems good company, we don't know, even the same company may manufacturing few Branded Purifiers
Yes, it's mostly from the water truck, but also from BBMP lines, a borewell and I have rainwater harvesting as well. It's a mix of lots of different waters so tds varies between 300-380.
I found dealers who are just selling brands like kent and aquaguard. Did you mean I should get a subscription for water purifier?
My water filter is not branded. Just a local make. Aqua something.
meant something like this. similar to what i use -> https://www.amazon.in/R-K-AQUA-FRESH-INDIA-Technology/dp/B09V83KBYN
can be serviced by yourself.
for your rainwater harvesting how many layers of filtering are you doing?300 to 380 tds isnt bad
Reactions: imad7x
good that with generic user can save compare to branded but than spares are not available and if available not perfectly fit, as @6pack don't have good experience with replacement/spares
most of the generic models are similar in shape and size. nowadays, you have full length and truncated filters of varying sizes available. I started service of my RO from 2016 or 2017 when I saw the the entire kit was available online on ebay for 1.1k. since then i've been buying the entire service kits online (ebay or amazon).
Reactions: Emperor
would like to click image of your Generic Water Purifier and post here, it's good that still it's spare available in market and one can replace/install it without Tech person help, technician charge 500-700 for first installation + Rs.2500/3000 as 12 months AMC
By the way, which brand is better to prefer, for a tier-3 city?
My relatives are old people, they just want something that works well and service people that doesn't cheat. Their experience with aquaguard has been the worst.
My generic RO system. Bought in 2015 for 4~4.5k. Can be maintained by ourselves as there are no complex parts. Membrane last changed 2.5yrs ago. Input TDS is 750+ and output RO water is 50~75TDS. Only issue so far, it started to leak near the water display section in the storage tank. Sealed it with epoxy resin and hardner. Thats the brown lining
Reactions: Emperor
For Every one who is using RO Water System, please click here and read Why is the RO + UV water purifier not a good option? and let me know if it's true.
By now it's like common knowledge that more minerals are removed by RO. Almost every model now is RO, without this thing options are limited and we always might not feel confident without RO. But that's the water we get everywhere whether we use purifiers or buy cans or bottles from shops/brands.
The default water we get from govt, is getting a little harmful than before.
The question is what we can do about it or how we can go back to having good old water.
how about installing & using NON RO water filter?
