Which replacement cable for TF10?
^ There aren't very favorably reviews for the Null Audio as well (Baring 1-2 , which ofcourse one can't totally reply on :P ) . Most probably I will have to pick up the UE Rainbow even though it looks a it bit ugly :(.
how much for the rainbow ?
and that ugly look can be hidden by using sleeves ( they might have a sleeved cable option )
Bought the Pearl for $40 off Head-Fi :) will share impressions once I get my rig in the coming weeks.
hi firends,
i am enjoying my triplefis.
but one thing for sure is cable is gonna go bad early with all the twisting and pushing we need to do with it.
has anybody tried UM replacement cables on triplefi? i see that it retails at around 2.7k INR on Lynx India. is it any good [i underatand the pins need some finlling and chopping to fit them in].
The popular after market cables are the way to go. If reviews are to be believed they make the mids better and off e-bay are probably cheaper than 2.7k.
Sorry to bump up this old thread, but my tf10 is giving out lower volume in the left side, so I switched the sides and checked. My cable has gone bad :( Can someone suggest me a cable for as low as possible? Even used is fine I guess as long as it is not costly. :(
