Well guys tower is 700 meter from my house , I think
Their is a BSNL tower their so i think GSM and CDMA are together only
What do you guys say ?
I have not checked upload speeds
In utorrent i am not uploading anything of value
These are old HD rips which couldnt download as their was no unlimited connection
tell me how to check the upload speed and i can confirm .
Everything depends on signal you are getting
I am getting around -66 dBm in day and -63 dBm in night approx
programming this is very easy
but as varkey says BSNL cooperation required for the Primary and Secondary Channel A and B
and SID and NID
all these can be taken from any working EVDO datacard also of that city
Guys with a good parablic or yagi antenna the signal should improve
In the link i posted people made a 10 mile connection, with no amp so good antenna seems a valuable investment for a wireless connection downloader
I dont have the pigtail otherwise would have checked that
I have the patch antenna BSNL gives and am sourcing the pigtail from ebay
http://cgi.ebay.com/N-Jack-SSMB-plug-right-angle-pigtail-cable-RG316-/160558048504
seller is confirming whether it will fit according to my specifiactions
Gannu said:
Sabby, dude could we lend some help from kuduku/varkey to source this modem and unlock it? Seems like the investment may be worth it. What say? :)
I'm in mate. But before that, I need a demo at my place. I called up the local CSC and the demo rep said his DEMO SIM/device has some problem right now. Also, he said that in my area the avg speed I'll get around 300-400kbps. Still I insisted for the demo, he asked me to call him after a week and if his device is ready he'll come to my place. So I have to wait for that demo or I'll need varkey's help to test the speed. If speed is even around 1Mbps, I'll take the connection. :)
@varkey, how's the speed you are getting in potheri ? I guess the nearest tower for you will be MM Nagar.
can we unlock novatel 2200?
it will be so awesome,
750 rs per month for wifi access point?
kudoku,
any help from that unlock ucranian forum?
well i had posted links here for unlocking the MIFI for you
I might unlock it no guarantees but for that i ought have the MIFI
It would be hit and trial as i dont have any of those paid versions
So i again repeat no guarantees but it can be done
well was surfing ebay.com in night
Saw the latest Fivespot Global Ready 3G Mobile Hotspot Verizon in an auction from a good seller
Just for the fun of it put a bid and won it
The latest MIFI in US market which has GSM and CDMA both
3G Mobile Hotspot, Fivespot Global 3G Mobile | Verizon Wireless
Please help. I have a prepaid bsnl evdo ruim (data only) which is already activated. i bought this from a guy from Nagpur.BTW i'm in Gulbarga, Karnataka. And i found this modem here
Code:
http://www.techenclave.com/classifieds/item/612-bsnl-evdo-modem/
(looks like ZTE AC8700)
Can i use my RUIM in this modem?(i have a cracked version of CDMA Workshop 2.7 and know a tiny bit about activating the RUIM slot)
Will it need any programming?(i have no idea about this part)
Will it work in EVDO or 1x only? (i read somewhere AC8700 works in 1x only if used as RUIM-based)
Thanks
As you said Sierra Wireless 595U is not available , try searching ebay that the best bet .
If you are getting 180-200 in a data card which has very poor signal then i expect in Sierra you will always get 250+
But do you want to spend 1k for a speed bump of 50 KBps . But Sierra Wireless does pull signal when none are available and in night i can expect speed bumps to 300 KBps at your place . When ZTE AC 8700 show no signal my sierra shows 2 signal bar with a download speed of 40KBps
Now you decide ,if i find a good deal of the sierra will email/pm you
Does BSNL register MEID of the SW card ? what is the charge and how diffficult is the process
#[member='cisco_tech']
#[member='varkey']
#[member='hA1d3R']
#[member='Gannu']
The Sierra 595U is hard to find even in ebay.com. Any other Rev A RUIM card that you guys would recommend?
[font=trebuchet ms,helvetica,sans-serif]Worth it? Since we might not know the condition it might be in. Is it easily unlock-able?[/font]
[font=trebuchet ms,helvetica,sans-serif]Anyone here using EVDO prepaid? I might get it only for testing now. [/font]
[font=trebuchet ms,helvetica,sans-serif]Earlier got a EVDO postpaid 750UL and surrendered it in 1.5 months due to poor speeds. But ended up paying for 3 months since BSNL insisted that it is the minimum hire period
(No mention of it in the website and no prior info given while taking the connection. So don't want to do a costly experiment again)[/font]
[font=trebuchet ms,helvetica,sans-serif]Was wondering whether I can activate it for Rs.500 and use the 500MB Rs.150 prepaid plan for testing and then shift to Rs.750 UL prepaid plan. If yes, how to recharge and switch plans in prepaid?[/font]
[font=trebuchet ms,helvetica,sans-serif]Can anyone from Blore let me know if there are any EVDO towers in the Madiwala/Silkboard area?[/font] [font=trebuchet ms,helvetica,sans-serif](Might go there for summer)[/font]
[font=trebuchet ms,helvetica,sans-serif]P.S: Currently have a ZTE [/font]AC8700 [font=trebuchet ms,helvetica,sans-serif]that I deactivated 5 months ago (TN)[/font]
SPC of sprint cdma products is non-zera which makes programming difficult if i am not mistaken .
I have bought a MTS ZTE AC2766 with ruim model , hopefully will be testing BSNL EVDO in TN within the next week . everything else is costly....2G is capped making it unusable .
@hA1d3R replied back your pm , if you have good signal nothing better than 595U and as i said spend $5 for the unlock
issues only come with bsnl branded data cards
otherwise customer purchased non BSNL braned data cards are not a issue . Just take a normal new EVDO internet connection and you are good to go
If BSNL guys are helpful will even program the 595U for you , if cheeky and oldies are sitting than you will have to do it
@DarkAngel[font=helvetica, arial, sans-serif] [/font]
my both 595U were used when i bought from ebay
only thing to be checked is whether usb socket is not loose as this is a notorious problem here
When its only used in usb slot and not with an extension or cradle the usb socket gets loose due to its heavy weight and it will stop recognizing it
then its equal to a paper weight
http://www.ebay.com/sch/Computers-Networking-/58058/i.html?_nkw=595u&_catref=1&_trksid=p3286.c0.m1538
http://www.ebay.com/sch/Cell-Phones-PDAs-/15032/i.html?_nkw=595u&_catref=1&_trksid=p3286.c0.m1538
not a hot selling item but deals can be found less than $10
and varkey found one in amazon also
I had BSNL ZTE model and my 595U in a remote place.
ZTE shows no signal and 595U shows 2 bars and gives me a download speed of 30-40
I go to remote place local BSNL exchange asking about details of EVDO and to my surprise the town doesnt have EVDO
I insist i am getting EVDO and the curt reply it would be 1X
i always keep my modem to EVDO only so knew i was correct , so no use banging my head and quietly left the BSNL office
so the crux of the story is same this is the best modem in world in terms of speed in my personal preference
I have ordered the 595U from amazon. and it is on its way to india. will update this thread with my experience and all the procedure.
#[member='kuduku'] thanx for the help bro.
you are welcome man , and i still believe its the best datacard in catching signal . I have the BSNL zte and sierra 595U connected to my laptop , both facing the same direction . ZTE is not showing any signal as i am in a very poor signal range area wheras sierra is giving a download speed of 100+ . Its unbelievable and surreal to see that . Enjoy your purchase and my recommendation get the external patch antenna from bsnl and i will send the ebay.com china seller link who got me the pigtail to connect it with the datacard and antenna cable . you will get not less than 250 in download
Hmmm.. Interesting thread for me as well. Already have a BSNL EVDO card with the shitty Capitel data card that shows signal at full 5 bars and my downloads crawl at 20 ~ 30 kBps
#[member='cisco_tech'] - do let me know how things work. May buy one myself
mine is the micromax one.. and I get around 330 KBps download speeds on torrents and http's.. not bad for 750 pm
err.. it might be since there are not many EVDO subscribers in my city..
and i reckon the tower is around a km from my house.. or rather the exchange
i generally download 1 - 1.5 GB of data in an hour or so..
