Yes hayabusa did it with the same tool , changed 598varkey YGPM, can we flash this one using the same tool we used for 595u. I believe i read in some of the posts by kuduku that it was possible and hayabusa did it.
^ If you are using the STV, then its Rs 825/830 depending on the circle. The STVs have to be done through BSNL Special. If your plan is the Rs 750 unlimited which is automatically renewed every month, just do a topup so that you have useable talktime of Rs 750.
It is better to convert the base plan to EVDO General and go the STV way as you have better control. As you can activate the plan whenever you like it. There are 15 day, 7 day, 1 day plans as well.
^ For South Zone users, we have an excellent portal to manage and view all details regarding the connection -- CDMA Customer Portal: Login
So for me, the plan and recharge status etc are shown there.
Did you select the operator as "BSNL Special" when you recharged from ezRecharge.in?
^ I never really tried the *123# method, but it should be the same eitherway.
No, balance didn't increase, only the validity.
Requirements , usage , distance from tower , WIFI router model or normal data card ?If I am to get a device from the US could you please guide me to which one I should get?
ask bsnl to give a demo and than decline due to bad speeds . buy from @varkey you will get a fully ready device , no need of even configuring . Ask @varkey he willconfigure it when you buy from himI need it for normal usage. Don't need a Wifi router, etc. Just to connect with my laptop. I'm not too sure about distance from the tower, is here any way I can check this?
thats normal , no issuesView attachment 16754
@kuduku @varkey
Any idea why is it saying user name & password bad program/parameter ? Shall i erase every thing & write that data from beginning ?
Can some one plz upload ESN unlocking software>? my modem is sierra 595u
