@DanteErodov Does the CL14 or the CL16 have any noticeable difference in a real world scenario. As in can these differences be perceived ? I have at different times used both of them and could never find any difference in everyday performance ?
There is no real perceivable difference to be honest. However, there is some difference if you try to look for it. Moreover, you cannot simply compare CL14 vs C16. It is a combination of both speed as well as timings that matter & are comparable.@DanteErodov Does the CL14 or the CL16 have any noticeable difference in a real world scenario. As in can these differences be perceived ? I have at different times used both of them and could never find any difference in everyday performance ?
You can refer the below article to see how Ryzen behaves at different speed while gaming. If you go through it you'll note that the highest speed RAM are not the fastest & the lowest CL timing RAM is also not the fastest. It is a combination of both high speed & lowest timings that really matter. Also in the conclusion you can see that the sweet spot is usually at 3600Mhz CL16 or 3200MHz CL14 timings & achieving anything above that depends upon a lot of factors including your RAM, motherboard & CPU. Personally I would go with 3200Mhz CL16 kit as those are usually significantly cheaper in our market than 3200MHz CL14 or 3600Mhz CL16 kits & paying a premium of more than 40-50% is simply not worth it & is better spend on upgrading something else in your system.
Ryzen 3000 Memory Benchmark & Best RAM for Ryzen (fClock, uClock, & mClock)
Memory speed on Ryzen has always been a hot subject, with AMD’s 1000 and 2000 series CPUs responding favorably to fast memory while at the same time having difficulty getting past 3200MHz in Gen1. The new Ryzen 3000 chips officially support memory speeds up to 3200MHz and can reliably run kits...www.gamersnexus.net
One of the guy I know have it with him(F4-3600C16D-32GTRGC), was thinking of taking it just wanted to know if it worth it.It is most probably Hynix c die based upon the information present in the below links. Basically anything with GTRG is Samsung B die based upon the first link but based upon the 2nd article, anything ending with an extra "C" on B-die code is actually Hynix C die. The only way to know for sure though is to confirm it with someone who already has it.
B-Die Finder
Find Samsung B-Die DDR 4 memory kits on Amazon, Newegg and many more.benzhaomin.github.io
Hynix C-Die vs Samsung B-Die 2x16GB kits
I am trying to find information or a review comparing these two kits, but have had no luck finding a comparison so far. There are 2 kits made by G.Skill in the Trident Z Neo line: F4-3600C16D-32GTZN, Samsung B-Die, 16-16-16-36 timings, ~$300 F4-3600C16D-32GTZNC, Hynix C-Die, 16-19-19-39 timings...www.overclock.net
Are you able to find this kit in stock though? Honestly I wouldn't really worry about this as anything with 3600Mz CL16 timings is pretty good to begin with. Also it is very unlikely for you to be able to find Samsung b die kits in India. You can also try searching for 3200 CL14 kits as those are also Samsung B-die and can be easily overclocked to 3600Mz CL16. This is one such kit which used to be available earlier but has not been in stock from quite a while now. https://www.amazon.in/G-SKILL-3200Mhz-PC4-25600-CL14-14-14-34-F4-3200C14D-16GFX/dp/B06XFT7DF9
Edit 1: Found one Samsung B-die, https://www.primeabgb.com/online-pr...16gb-3200-mhz-ddr4-memory-f4-3200c14d-32gtrg/
Edit 2: Found one more Samsung B-die kit,https://www.primeabgb.com/online-pr...16gb-3200mhz-ddr4-memory-f4-3200c14q-64gtzsw/
Sorry for the noobish question at the end of such a technical discussionJust make sure it also has good CAS latencies too. I think a 3200MHz Cl16 kit will perform similarly to a 3600Mhz Cl19 kit, so no point in going for that, more details here https://www.techpowerup.com/forums/threads/3200-cl16-or-3600-cl19.247608/. Ideally you should go with something like:
https://tlggaming.com/gskill-tridentz-neo-F4-3600C16D-16GTZNC?limit=100
https://www.pcstudio.in/product/gskill-ripjaws-v-16gb8x2-ddr4-3600mhz-c16-ram/
If you really want to find good overclocking memory you should try to find something from this list: https://www.reddit.com/r/Amd/comments/62vp2g . It is a bit old but contains lots of information.
I'm getting G.Skill Sniper X 3600mhz CL19 2*8gb locally for 5.5k. Do you think I should go for it? Or should I specifically look for 3200 CL16 ?
Is it possible to run this 3600 CL19 kit at 3200 CL16?
I think you should go ahead with your purchase specially at that price point as the real word difference between them wouldn't be noticeable at all & that is a very good price IMO.Sorry for the noobish question at the end of such a technical discussionbut I'm getting G.Skill Sniper X 3600mhz CL19 2*8gb locally for 5.5k. Do you think I should go for it? Or should I specifically look for 3200 CL16 ?
I may be late to suggest, but if you can find Crucial Ballistix Sport LT which is E-die memory and extremely good performing overclocker. I have bought 2 sticks of 3000MHz CL15 and running them at 3600Mhz CL16 comfortably !Sorry for the noobish question at the end of such a technical discussionbut I'm getting G.Skill Sniper X 3600mhz CL19 2*8gb locally for 5.5k. Do you think I should go for it? Or should I specifically look for 3200 CL16 ?
TPS Tech usually has loads of Ballistix in stock but apparently just one model is available and it costs a pretty pennySport LT has been discontinued, I've been looking for it everywhere. Ping me if you're planning to sell lol
Can you link? Are you referring to the RGB one here https://www.tpstech.in/products/cru...top-gaming-memory?_pos=1&_sid=1dcad700e&_ss=r They don't mention the product code for some reason and I'm skeptical of the "15-16-16-35", it's probably a CL 16.TPS Tech usually has loads of Ballistix in stock but apparently just one model is available and it costs a pretty penny
Hey, don't sweat about this stuff, it really isn't a big deal. On the bright side, I found this reddit thread where folks are talking about your specific kit that you could get for 5.5k. As per the discussion, it seems like it could run at around 3600MHz CL16 with some tuning so take a look.Ballistix Sport LT 3200 was available for a short period on Tuesday on TPS Tech for 3499. I spent too much time thinking if this is good or not and missed out![]()
They had it a month or two before when I checked. Friend bought 16gbx2 ddr4 3200 sport LT from them for 10k something. They had stocks of 8gb stick then tooThey dont have Sport LT though.
Damn that's a good price!They had it a month or two before when I checked. Friend bought 16gbx2 ddr4 3200 sport LT from them for 10k something. They had stocks of 8gb stick then too
