Revolution
Contributor
Me from Jadavpur area.Revolution said:U getting 1mbps speed with 2G 98 3GB pack ?
Which area ?
avi said:JuGGa where are you ? your trick worked ! Bashed reliance like hell, they have removed the quotahyeah: :hap2: :clap:
JuGGa said:Yay, congosParty to banti hai!
hyeah:
Revolution said:First I mailed with technical lesson and then sent mail with strong word but nothing worked for me.
may be my bad luck.:'(
avi said:^recharge was fail man. The dealer tried twice & nothing happened. :
avi said:oops. top up of 98 ? but what if that gives balance ?
*hopes are back again*
@Revolution - Yup. Scold them. Call them liars & thieves. Demand u like to talk with GPRS Tech when call connects. And demand again to talk with superiors. Scold them. Call them liars & thieves.
The result, either should they disconnect the call frustrated & block ur SIM OR remove the damn cap
Just went to the dealer for top up & when entered 98, it said Invalid Denomination :|
avi said:It is 98. BSNL has same all over India, isn't it
avi said:^Seriously ?
Btw I found a old reliance sim which has 487 in downlinkWill try speeds in that
Revolution said:I'm damn serious.
Both my SIMs are 2 and 3 years old.
