Would CX400 be able to handle a 5850? The spec for the GPU says 500W. Also, the GPU requires two PCI-E connectors....Mephistopheles said:Then get a CX400 or if you can spend some 500-700 more then get a VX450
Lol! a VX550W! You got to be kidding me!ALPHA17 said:Go for atleast a Corsai VX 450W or for a breathing space pick up the Corsair VX 550W
Grab a Seasonic S12II 520w. The perfect fit for uAnkur said:Budget: can spend upto 4k
GPU: want to use something like 5850
MoBo : Abit IP35e
Proccy: Intel Core2Duo e6550
RAM 4Gb DDR2 800Mhz
for which PSU should i go?
can stretch my budget by some bucks if i get something good.
Yeah, go with what DarkAngel has suggested, although a Seasonic S12II 430W would have sufficed but for that budget Seasonic S12II 520W is a good buy.Ankur said:Budget: can spend upto 4k
MoBo : Abit IP35e
RAM 4Gb DDR2 800Mhz
Get Seasonic S12II 520W, period!Ankur said:thanks for your kind avise both you.
keeping in mind, future upgrades. suppose i upgrade the proccy to i7, or x6 and Mobo to a DDR3 capable one. around 6gigs of RAM and something around 5850 as a GPU then which one should i get. I really liked the range from Seasonic. Wont mind spending some more keeping an eye for future upgrade. AS i dont want to spend again on a PSU for next 2 or say 3years.
Yeah, dont worry you'll be fine with that PSU and will handle all your future needs as well, but dont get too carried away with it and get a monster like 5890 etc. and run it on this PSUAnkur said:OK Sir. As you say will place the order with ITwares tomo on your words.
Just out of cuorosity i wish to ask that why there are very high potential PSU's i.e like 750W or 850W.
lol earlier i made my mind on getting Seasonic 12D 850W until i read your saying.
and please once again. should i go wi S12II 520W on your advise?![]()
hmm..get a Corsair VX550W if you plan to stick with one GPUISHROCZ_14 said:anything .. corsair .. cooler master .. ocz .. suggest me 1 good caompany !!! i wont worry about budget cause once got nice psu then i wont take another 1 for ages !!!
hx850 is an overkill for the system !Desecrator said:Corsair HX850 - has a 7 year warranty as well. Costs just under 10k, is 80+ silver certified and would definitely last you for all the upgrades to come.![]()
