v.Na5h said:is there any cheaper alternate to vx450
how is cx400 will it be able to support my config- below sig.
should have enough headroom for OCing
wat about
Tagan Stone Rock TG500-U37 500 Watt
its cheaper at 3.2k
Karthi007 said:@Rockfella - I guess you meant the FSP SAGAII 350 PSUIts a VFM PSU for 1-.6k~
H2O said:I have decided to get rid of the generic power supply that came with my rig. I actually wanted to get a Zebronics 350 Real Watt. But, it wasn't available with my dealer at that time. I have a modest budget.
The PSU will be powering a
AMD Athlon II X240 -2.8GHZ
Asus M2N68-AM PLUS
2GB DDRII 800mhz RAM
Seagate 500GB HDD
XFX 4650 1GB DDRII
Samsung DVD Writer
I have no plans of overclocking my computer in the future I'm looking for something stable as my computer stays on for 16-17hrs a day.
I am also open to used products so if someone could suggest some products which could be open in this price range I would post in the market section.
~H2O
shivamrockz07 said:Which one to buy out of these three : FSP Blue Storm Pro 400W, CX400 and Seasonic 380w? Why?
Rockfella said:Seasonic 380w, just get it.:hap2:
Rockfella said:FSP Saga 350 IS THE BEST BET 4 U.
shivamrockz07 said:Enough to power:
Athlon II X4 620
HD5770 1GB
4GB DDRIII ??
Cm500w is a true 500w psu which can supply peak 500w while being 74-80% efficient (which has nothing to do with how much power it can provide).
shivamrockz07 said:Can I get an answer here pls.? Need to buy tomorrow...
The Sorcerer said:^^ Why not just use your coolermaster 500w? Aren't you the one who made this comment in the first place?
http://www.techenclave.com/1376453-post6.html
And I quote...
If you're claiming that this is what it does, why are you not getting it? OR is it you don't have any confidence about what you're claiming![]()
shivamrockz07 said:.... I have decided to get something of a better quality/efficiency to lower my bill amounts and to get some clean power.
