hayabusa_ryu
Contributor
I think that same tools can be used to fix ESN of 598. If not BSNL officials will register the new ESN. But first, guys like kuduku, Cisco, dushie etc are available to sort it out, If unable to do so BSNL is there
I talked to EVDO officials today about my device. They suggested me to write a letter to SDE for an ESN change mentioning the ESN nos. of both old and new devices. They also told me that it wont cost anything for changing ESN from old to new device and it will take one day to do the process although it's only a work of 30 mins. I asked about upload capped speed but they told me that there is no such thing as capping here and it solely depends upon the no. of users and distance from the tower. Let's see how true are they although I find them very nice as compared to other BSNL officials.
Just waiting for the device(I may get it before 5th Oct). Is it still beneficial to do all the stuffs as suggested by Dushie?
I find BSNL device pretty useless as compared to Huawei etc unless you are in a VERY good signal area or with less no. of users(I'm talking about 2mbs+ speed here). You need to use Antenna to compensate for the device but the latest offerings from BSNL etc don't have any external antenna port that's why I went for 598U. I took out antenna of old ZTE device and put my custom made omni antenna for the better result otherwise I don't get good speeds using the ZTE device with default antenna.
- - - Updated - - -
Do MTS ZTE 2766, MTS ZTE 2746 or any EVDO device available in India have external antenna connectors? Plz confirm it.
I can but theres a limit to things i can change on 598 . I cannot put all the details of RUIM on 595 as everything cannot be changed on 598 . The only option you have is taking a new connection with your esn or changing existing connection esn . Before that you should have taken out all details from RUIM or existing connectionI think kuduku can do all the process via Teamviewer if I needed to do any flashing etc
Guys i have got the SIM and the modem from BSNL,now how do recharge or top up my card plus how to check whether its got activated!!!
