cisco_tech. I added the All India PRL file and also rechecked the username / password. On the new connections they are giving a 10 digit mobile number starting 9 so for username / password I added like
9XXXXXXXXX@aaand.in and password as 9XXXXXXXXX. Is that right?
Similar would be the case for MIN A and MIN D are your tele number with STD CODE
Now its a 10 digit number so if I add STD code before number - the number would be 12 digits - hence I added the first 3 digits and then next 7 digits. or do I need to add STD code and then remaining digits?
I am not able to connect via watcher. It says initializing > then shows the EVDO A > -60 to -70 db and then says connecting and does nothing after that. After a few minutes it simply says searching and then the db changes to -125.
I created a new dial up connection and it begins connection then verifies username password and after a minute or so gives error
Any help? Thanks
