pawannh said:Sorry racy1. I'm cluttering your thread with second GO as well. I hope you don't mind.
Update from KMD for second order. Order has been already placed, but processing has not yet started (I assume at thomas distributing) due to some xyz reason. We will have ETA after 3-4 days.
racy1 said:Received my kit today in good condition..... The charger is actually smaller than what I had thought...![]()
Currently refreshing my old Ni-Cd batteries & then will check the batteries from the kit... the quality is quite good... :hap2:
Thanks to KMD for accepting the IC & getting the product pretty fast.... :clap:
pawannh said:How come? Thomas distributing is claiming that they are sending V33!
The only way to tell the version number of the station is to turn it on, the version number flashes for a moment when the station is turned on. The packaging is not related to the version number, as both versions were shipped in boxes and plastic. There is no difference in the functioning between the versions, the only difference is when they were manufactured.
pawannh said:I do not believe that there is no difference in these two revisions. Manufacturer will not put in effort to release new firmware if there is no gain. Its other thing that sometimes changes fixes one case but adds other bugs![]()
kooabs03 said:^^^ Just go through the manual. Its easy. BTW my charger doesnot give any display in the second and the third slot. Is it normal? the 1st and the 2nd slot shows current in mA.
