I reckon there were some deals in the dealer section for Seasonic PSUs, check it out if you cant find it locally or else you could also go for VX550W which ideally you should get easily locally. Both of these PSUs will be more than sufficient for you with decent upgrade headroom.Marcus Fenix said:Can anyone tell me where to get the Seasonic 520W bronze PSu in Kolkata.Can it handle a phenom ii x4 955 OCed and HD 6870 smoothly without issues in the long term.it is either the vx550 or this 520W for me.How's the warranty and A.S.S. of Seasonic in Kolkata?
Incontrovertibly YesMarcus Fenix said:The only reason for Seasonic is that it is about 1k cheaper than vx550.will the longevity and reliability of this psu be enough in the long run?
Who said that is not true? My answer was for this:Rockfella said:Corsair has better ASS!
fatjivi said:i have a cm gx 750 w
processor:i7 950
gpu: gtx 460 1gb SLI(two gpu's)
is my psu good enough to OC my gpu a bit and my proccy upto around 3.8ghz??
processor:i7 950
try getting FSP Saga II 400 or 500Wneojjjk said:9500gt/8600gt
one CORSAIR 2GB 240-Pin DDR3 VS2GB1333D3 G
HDD sata 40gb/80gb
athlon x2 & mobo AM3 ,80mm,120mm fan in cabby is my config ...
planning to get FSP saga 350w ...is it a good psu to handle the above config ?
are u sure that 350 is not a good choice ?harishgayatri said:try getting FSP Saga II 400 or 500W
