The Power Supply Unit recommendation thread!
My dealer is saying that cx400 is not in stock right now,i am confused between cx400 and fs[ saga II 500.
Why dont you buy it online? You can buy it from theitwares...
I have to return cx430 to my dealer,i dont know if he will give me refund,so as long as he doesnt get cx400 i would have 2 wait or buy another psu from him.
wen u got it?
he is taking the psu back,need to get psu under 2.7 or 3k.
config- pro-phenom II x4 955,mobo-m4a78ltm,case-zebronics bijli,gpu-sapphire hd 6850,ram-corsair xms3 4gb1333.
Oh gr8.
Phenom + 6850, u should get past CX400 & FSP 500..
Corsair VX450 -3.5K is a better buy for ur rig..
thegatekeeper said:
How about cx500
CX500 < CX400 in build quality...
And for the record, CX500 is not 80+ certified... Strictly NO GO..
Check the prices of VX450 n Antec EarthWatts 500W, get whichever is cheaper...
P.S : Pls dont compromise on a PSU...
If you are not able to get a CX400 then you are better off by extending your budget a bit and going for the VX450 or a CM Real Power Pro 460w.
CM Real Power Pro 460w is not a good unit...
@DarkAngel, pls dont suggest real power n extreme power series from Cooler master... they are similar to generic PSUs...
@thegatekeeper, stick to VX450 or Antec EarthWatts 500W, on overloading both the PSUs were able to deliver 570W w/o burning the unit...
Antec EarthWatts 500 W
Corsair VX450W
