The Power Supply Unit recommendation thread!
I had till date used 3 Corsairs and 2 CM.
Both CM gave awesome performance. Both delivered what they promised. I even had the much debated and rejected CM extreme power. That was running my AMD X4 9550 and 4850GC smoothly with never drop in power or unstability. a simle HWmonitor running in the back when I watch HD movies or played a game was my basic indicator.
Post CM EP I took TX750, it failed twice. Only saving grace was that the Corsair service is impeccable. Got brand new replacements like in 5 days. But due to lack in faith in TX series move to Silent Pro CM and that too worked brilliantly. Niether the components nor the outter box seems anywhere to sub-standard.
But since one experience was bad with Corsair i wouldnt say its bad company either so went now to HX 850 and its working as good as all the review sites had commented. Very stable n silent.
In end yes if anyone asks me preferences of brand I would rate Corsair higher than CM just because higher end Corsair are more efficient and VFM, compared to a CM. Real Power pro CM which would compete against a HX850 is not at par on efficiency and noise levels.
Seasonic is brilliant brand, however think CM n Corsair service in India makes it my third preferred brand relatively.
As Asingh said its personal matter of preference. But would agree also with Gowtham and Striker that CM is brilliant and should not be out rightedly reject. It is great product from the price it asks, and plus 5 yrs warranty and great service in India.
i dnt knw why guys here r fighting.. i enquired about antec for two reasons
1)i am on tight budget
2)i read good reviews on newegg of particular two psu i mentioned
anyways will corsair vx460w will suffice for
core i5 750+asus p55d or msi gd65+some low price graphic card as i am not interested much in gaming + 1 internal hard 1tb + 1 external hard disk 1 tb + monitor benq2420hd or samsung p2350 + gskill rigpaw 4gb ram?
The best psu u can go for is seasonic 380W :)
SLI Query?
I have a desktop PC running off a GlacialPower AL650AA PSU. I want to know if it will be able to run the desktop if I add one more GPU to make it run on SLI mode.
Currently my system config is as follows:
CPU Type: DualCore Intel Core 2 Duo E6600, 2866 MHz (9 x 318)
Motherboard Name: Asus P5N32-E SLI (2 PCI, 1 PCI-E x1, 3 PCI-E x16, 4 DDR2 DIMM, Audio, Dual Gigabit LAN, IEEE-1394)
System Memory: 2 x 2 GB OCZ XTC Platinum DDR2-800 DDR2 SDRAM
Video Adapter: NVIDIA GeForce GTS 250 (512 MB)
Disk Drive: ST325082 4NS SCSI Disk Device (250 GB, 7200 RPM, SATA-II)
ST350041 8AS SCSI Disk Device (500 GB, 7200 RPM, SATA-II)
Optical Drive: SONY DVD RW AW-G170A ATA Device (DVD+R9:8x, DVD-R9:8x, DVD+RW:18x/8x, DVD-RW:18x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
Re: SLI Query?
yes it will handle GTS 250 SLI with UR Config
^ Of course not a problem...however GP 650 I guess has only 2 X PCIE Express pins. SO if one GTS 250 neads 2 X 6 pin connectors it might be an issue.....U can use molex to 6pin connectors of course for the other card but usually its not recommended.
I think he can safely do so. Using those converters. Though as you said, native PCI.E 6+2 pin is the best. He can create one PCI.E using 2 molex ---> 1 PCI.E 6 pin converter. And keep it on separate loops. Works for me --- till now, at least.
Mine is a AL650AA and it comes with 2 x 6pin molex connectors for run SLI/Crossfire. I already have one 6 pin molex connected and the other one is still free. So I dont think I would have to use any kind of converters. I was actually concerned if the PSU would be able to run the two cards at the same time or not?
By sabret00the, shot with FinePix S5800 S800 at 2010-02-07
i will be buying one of these motherboards h55, h57 , p55 , q57
can anyone tell me which one to choose and also i m going for 19 inch lcd any suggestions???
Re: SLI Query?
Instead of SLI see if u can buy a single powerful card like 5850. Few games will scale good in SLI mode. It is waste tbh.
Well i have an 8800gt Sli almost all major games scale well if you have proper driver support but finding the right driver for your config is a PITA but once you find it no need for driver updating just update the sli profiles when they are for the games you want :) The problem i face is that i run out of Vram at high resolution(512mb) i guess if you need to play on Hd atleast consider a 1gb card for Sli :)
I would love to do that buddy but I already own a XFX GT250 512MB (at the max 6 months old) and I also have a SLI board. So the cheapest and easiest upgrade option for me is to get another GPU of the same specs and add it to the exisiting rig if the PSU allows that. Further, I think SLI would make sense if we're talking Full HD.
asingh said:
SLI will give a performance boost. Multi GPU shines on that type of resolution.
Even I'm of the same opinion. I dont play so many games anymore. The games which I play sometimes is like ProStreet or GTA4 kinda stuff. Apart from games I would also need Full HD playability.
^^ Seems good. But do remember, GTA4 sees jack with respect to the GPU. It is mostly running off the CPU.
