antz123 said:@Asingh
game hmmm ... i always am...
Quoting your explanation:
This works:
PSU rating = 750W (A)
Efficiency rating = 80%
PSU Draw = 750 / (80/100) = 937.5 (B)
PSU Throughput = 750
Calculated Efficiency = (A/B) * 100 = 80%
However Power Draw isn't constant neither is efficiency.
First take a look at this link... as an reference for working of a good 850 PSU. in case its an HX 850 Corsair.
Corsair HX850W Power Supply Review | Hardware Secrets
You can see the efficiency is peaking at 50%-60% i.e. around 350.9 W - 515.2 W. (and btw this site i quoted becoz they dont test in idle conditions of (23C) rather is done in a hotter room.)
In your explanation of the thread i rolled you back, you have worked with an example where efficiency is constant and power going in is constant.
And when i said to buy a PSU whose 50%-60% Power through put is that what ones setups requirement is, then the system would be most efficient. Give more stability and also lesser in bills.
Further if you want to read-up on my reason to recommend a higher wattage PSU over "Right all you need" wattage can be checked here too: Understanding the 80 Plus Certification | Hardware Secrets
Hope sense prevails now..... and let me if my supposed over quoting of efficiency and 80+ helped now
@Antz123:
Okay, informative links. So Hardware secrets and 80+ certification process have a gauge issue. 80+ process is doing it at room temperature, and at three loads only. (20%, 50%, 100%). Your interpretation of the data shows that efficiency peaks at 50%-60%. Now let me transpose that data so it makes more sense. Not sure why hardware secrets created such a difficult data grid. I have only taken results for (3), which was done using their GWInstek GPM-8212 power meter. See the table below:
Now, where do you see the peak in efficiency..? It is under test 2 -- for 41.30% efficiency. But that is not the point. I have inserted a final column on the end "Delta_Avg". This is the Efficiency at certain load - average efficiency of all five tests. This will show how far the efficiency at a certain load is from the average efficiency of the PSU. It can also be seen if each row in inspected manually : As you move from 20% to 100% how much difference in efficiency do you really see...first 2 rows its mere 1%. Now you telling me, that 60% is the sweet spot, so in order to hit that, we should buy a PSU that is 50% over capacity than my anticipated load. Would you ..? When at 20% load and 41% load 81% load and 100% I am just as close to the efficiency level of the "sweet spot" 60%.
Example:
Some needs a 450W Corsair unit : RS. 3990
50% over that = 675W, we make do with 650W : RS. 7688
See the price difference and compare it two the efficiency level differentials at each load setting.
