Guys, need to buy SMPS , currently running a on local "NECOLA" brand smps.
Max SMPS budget = 1.7 - 3.5 K INR
System Specs - AMD Athlon X3 C2 ( unlocked ) @ 1.2750 @ 3GHz | 8 GB Mem @ 1.9 V | 1 Hdd | 1 DVD | 785G BioStar Mobo
System Load - mostly idle, general browsing,idle to high load using VMware Workstation (mostly stateless)
Might Add a GPU later such as 6870 or similar.
So suggest SMPS with above specs including gpu load...
1) Corsair VX 450 (seen posts that its OEM has been changed ... such as here in this thread and at
Corsair TX - Finding the truth - Page 4 - Overclock.net - Overclocking.net )
2) Corsair CX400 ( is it being phased out, if so, will i get CX430 in warranty replacement )
3) SeaSonic S12II 430
Also is there any change in pricing of this 430 model , as difference of 400 bucks in these two threads
2600/-
http://www.techenclave.com/dealers-paradise/seasonic-power-supplies-full-range-166027.html
3000/-
http://www.techenclave.com/pc-buyin...y-community-pc-buying-178097.html#post1642823
4) i had previously bought a FSP Saga II 400, which was a Kaput unit with IDLE 12V @ 12.7 and very low standby voltage ... which lead to situations where we can't even start Computer. ( measured using LULTILETER )... so i will try to avoid FSP Saga II { or may be that i only received BAD unit ... } ... FSP saga II 400 was though best in accord to mine needs ( excluding GPU )... anyhow leave FSP....
If corsair vx450 is changed , which one to buy ???
Also note that i am using a APC UPS
APC BACK-UPS ES 500VA 230V INDIA , and will there any compatibilty issues of a APFC ups and a SquareWave UPS output ... if i pair any of the above listed SMPS with this UPS ?
Regards
